Interesting Simplify3D Slicing Issue (Shifted Layers)
Posted: Wed Jan 20, 2016 11:03 am
The crowbar on the left in both pictures has shifted to the right(first image)/left(second image) in the middle at layer 28. You won't see it in the preview, but it prints that way every time. I tried all kinds of speed decreases, even modifying the travel acceleration and xyjerk setting to no avail! After I simply rotated the part -90 instead of 90, it sliced and printed perfectly.
Here are the crowbar files:
Sketchup
STL
Bad Slice
Good Slice
How to reproduce:
Import into Simplify 3D and rotate on Z axis 90 degrees for the bad slice.
Import into Simplify 3D and rotate on Z axis -90 degrees for the good slice.
If anyone is a GCODE wizard and can tell me what's gone wrong at layer 28, please let me know
Sketchup
STL
Bad Slice
Good Slice
How to reproduce:
