Concentric external fill pattern prevents bridging detection
Posted: Sun Jan 24, 2016 1:53 pm
by Zatsit
Do you know this as a bug ?
Take some model with a zone of needed bridging.
Set "External infill pattern" to "Rectilinear" => Nice slicing with normal bridging
Switch to "Concentric" => The bridging condition is not detected. A concentric pattern is put in mid air instead...
Workaround : place a special process with "Rectilinear" external infill on the layers surrounding the bridge.
Re: Concentric external fill pattern prevents bridging detec
Posted: Mon Jan 25, 2016 6:04 am
That makes sense. It's not easy to do bridging with concentric fill ;)
If you want bridging, you need to use rectilinear fill
Posted: Thu Mar 03, 2016 8:34 pm
by ConKBot
CompoundCarl wrote:That makes sense. It's not easy to do bridging with concentric fill ;)
Well this solved my question. The bridging test I was working on had bridges so narrow that the perimeter shells took up the whole width and there was no infill. I didnt notice I was on concentric infill. Perhaps a notification or greying out with a tooltip in the "Bridging" settings if you have concentric infill selected would prevent confusion?
