I am a new user to SImplify3d but experienced with 3d printing. I have an STL file that I imported. This model is a bit tricky- it has a lot of "gaps" in it, and the model needs supports in order to be printed correctly. I was hoping Simplify 3D would be smart enough to handle auto generating supports, but it doesn't appear to be able to. Here is a side view of the model:
http://imgur.com/D63zSul
When I try to auto generate supports (tried supports of size 1mm or 4mm) it puts about 10-15 supports on the model, and only in a certain area:
http://imgur.com/rqsRml2
As you can see in the image, it doesn't put all the supports where they would need to be, and the print quickly fails. I haven't yet gone through and manually mouse clicked to add supports, as that seems like it would take quite some time to do.
Any tips or pointers on what can be done?
