intorner
Simplify3D When can support D-Force?
Hello~
D-Force have 2 Extruder ,How to set the distance between them ?
I need you help~~thank's~
Re: Simplify3D When can support D-Force?
That printer is already compatible. It uses standard gcode, so it will already work with S3D, Cura, Repetier, etc (the product page confirms this as well).
So just go to Help > Configuration Assistant, select Other, then follow the on-screen prompts. I've setup my delta this way and it worked fine.
