Bed Levelling Wizard Issue
Posted: Wed Feb 03, 2016 6:12 am
by ComingSoon
Hello all,
This is my first post on this forum.
I tried levelling my build surface with the Bed Levelling Wizard tool but once I started, the distance between the nozzles and the bed was around 1cm instead of the paper-thickness gap I used to have. It was like this for every corner.
I never had any problems with the tool. I hope someone can help me resolve this issue!
Thanks in advance,
CS
Re: Bed Levelling Wizard Issue
Posted: Wed Feb 03, 2016 7:14 am
Maybe your Z-axis homing switch has moved.
You can see the commands that get sent in the Machine Control Panel on the Communication tab. It just does a G28 and then G1 moves. So if your G28 is positioning the nozzle a whole 1cm above the bed, then something with your Z-axis endstop is wrong.
