TrevorPhilips
AMF support??
As a Diamond hotend user I need to use a different slicing software (which sucks) for multicolor prints, so is the amf. file support / mixing extruder support coming to Simplify3D?
Re: AMF support??
Why can't you just use S3D for the multi-color setup? I use it with a 3 color extruder just fine. No need for AMF files, just import the 3 STLs
TrevorPhilips
Re: AMF support??
Yes I do, but some files I want to print is on amf. format.
jacobsdr
Re: AMF support??
AMF support would be nice
thenuker
Re: AMF support??
I'm about to install a Diamond hot end also. Can you tell me how you import the 3 stl's and define the colors? Is there a guide anywhere?
Thanks,
Nuker-
Re: AMF support??
You just setup a different process for each color and then use the "Select Models" button to choose what STL files get printed in each color.
This tutorial may be useful if you have never done this before
https://www.simplify3d.com/support/tuto ... -printing/
