Printrbot Metal Plus Settings
Posted: Fri Feb 05, 2016 7:31 pm
by jjones86
Is anyone successfully printing quality prints on their Printrbot Metal Plus with Simplify3D? My prints are awful. I've printed the same objects on Cura (what printrbot recommends) and they are flawless. The stock settings on Simplify3D Printrbot Metal Plus are pretty terrible. Makes me wonder if they even tested it with the printer... Any help is appreciated. Thanks!
Re: Printrbot Metal Plus Settings
Posted: Fri Feb 05, 2016 8:10 pm
If you attach a photo of what your print looks like, along with the factory file (File menu==> Safe Factory file as....) then it will give someone a chance of seeing what the issues are you are talking about...and hopefully offer some help.
Posted: Mon Sep 25, 2017 5:57 pm
by arountre
I have not been able to print using the defaults for PrintrBot Plus Metal Single HBP. Cura prints fine. The Z offset seems different in Cura vs Simplify3D, but this is a stored value, so I'm not sure why they would be different. First layer is never successful. Any updates on this?
Posted: Fri Sep 29, 2017 6:02 pm
by arountre
arountre wrote:I have not been able to print using the defaults for PrintrBot Plus Metal Single HBP. Cura prints fine. The Z offset seems different in Cura vs Simplify3D, but this is a stored value, so I'm not sure why they would be different. First layer is never successful. Any updates on this?
I was able to get a print to start by increasing the extrusion multiplier to 1.3. Why?
Posted: Fri Oct 06, 2017 4:24 pm
by drphil3d
problem solved, replace printrboard with replcape
