Help with supports for Ninjaflex
Posted: Sun Feb 07, 2016 7:10 am
by drmaestro
I need some help for printing supports with Ninjaflex. I have uploaded a video file below:
https://youtu.be/buxnUnDfvW8
As you can see, there are some problems:
1) It is difficult to print tall objects with Ninjaflex (it is the semiflex version), as they start to bend or wobble as the object gets taller. The supports have to be tall naturally, so do you have any suggestions on printing them (like ideal support angle or width, solid diaphragm).
2) Is there a way to design supports, specifically for Ninjaflex, using another software.
3) You can see that there are gaps on the supports. Is it because I am somehow underextruding? Is it because the supports are wobbly? I print at 20 to 30 mm/sec, should I go lower?
Thanks...
