Flashforge Creator Pro adjustments
Posted: Mon Feb 08, 2016 10:18 am
by stryker05
Im trying to print this watch stand on thingiverse, but when it reaches the overhang part it always fails, I tried adding more support or making the supports thicker the same thing happens always. Which setting should I adjust? Thanks
Heres the 3d file im referring to : http://www.thingiverse.com/thing:1306057
heres my 3rd attempt at printing:
Re: Flashforge Creator Pro adjustments
Posted: Tue Feb 09, 2016 6:36 am
It's hard to tell from that tiny picture HOW it actually failed. Did the support structures separate from the bed? Did the dial on top just not print correctly on top of the supports?
It doesn't look like that hard of a print, so I would think if you use the correct amount of support structures you should be able to do it
