Page 1 of 2
IR Z probe
Posted: Thu Feb 11, 2016 4:45 am
by erniehatt
I am trying to setup a Z probe for bed leveling.
I have setup Marlin as instructed, put G29 in the start script, but it still does not seem to do any level probing, is there some other setting I need to do in S3d.
Any help would be highly appreciated.
Re: IR Z probe
Posted: Fri Feb 12, 2016 5:52 pm
by SimpleScott
Did you do a G28 just before the G29? Some versions of Marlin need that. There are also some defines in configuration.h that have to be set before compile to enable G29, but assuming that's all correct try G28 immediately before the G29.
Re: IR Z probe
Posted: Fri Feb 12, 2016 6:03 pm
by erniehatt
Thanks for the reply, yes I have done the appropriate settings in Marlin, and the G29 after the G28.
Watching the G_code as it goes through the print, I see the G29, but it is being ignored. It just goes straight into printing the skirt.
Re: IR Z probe
Posted: Fri Feb 12, 2016 6:50 pm
by SimpleScott
What happens if you manually send G28 and G29 from the commands screen (rather than from the script)?
Re: IR Z probe
Posted: Fri Feb 12, 2016 6:59 pm
by erniehatt
Not sure how to do that
Re: IR Z probe
Posted: Fri Feb 12, 2016 7:03 pm
by SimpleScott
Open the Machine Control Panel, go to the Communication tab, enter the G28 in the field at the bottom and click the SEND button. Then after homing completes, enter the G29 and click the SEND button.
If G29 works OK from there... Then problem is something with formatting/sequence in the script.
If G29 doesn't work from there... Then the printer is simply ignoring G29. I would double-check defines in configuration.h file. In addition to ENABLE_AUTO_BED_LEVELING, you must have good values for probe positions and offsets. Feel free to post your configuration.h as someone may be able to spot a problem there.
Re: IR Z probe
Posted: Fri Feb 12, 2016 9:01 pm
by erniehatt
I am missing something here, I cant find a Communications
Re: IR Z probe
Posted: Fri Feb 12, 2016 9:13 pm
by SimpleScott
Click the Gear icon at bottom right of the main S3D screen to get the Machine Control Panel. There is a Communications tab there.
Re: IR Z probe
Posted: Fri Feb 12, 2016 9:20 pm
by wookie_666
If marlin is setup correctly then G29 will work. There is nothing else you need to do other than G28 before hand. Send me a copy of your Marlin file and I will have a look at it.
Re: IR Z probe
Posted: Fri Feb 12, 2016 11:04 pm
by erniehatt
Thanks Mate, will give it a go, and get back.
