cub22908
Dual extruder with Makerfarm
I just installed a dual extruder on my makerfarm I3V. Tried setting up S3D using "Other" and 2 extruders. S3D will not let me use Dual Extruder Wizard as it says I don't have any profiles that support dual extrusion. Anybody been through this before and know of one of the printer selections that would be equivalent to the makerfarm with dual extruders so I can use the Wizard? Thanks.
Re: Dual extruder with Makerfarm
I think I would use their Felix 3 Dual profile as a starting point. That should get you really close and then you can just edit the scripts and machine dimensions to match your machine.
cub22908
Thanks. I'll try that one.
