First Layer Height - What am I missing?
Posted: Mon Feb 15, 2016 8:58 pm
by Docmani
So I just purchased and downloaded the software. I'm trying to do my first print, but I seem to be making an error setting the layer height.
The default nozzle for my printer is 0.35mm, the first thing I did was change the nozzle diameter to 0.3mm
I went into Layer and set the primary layer height at 0.2mm.
I set the first layer height at 80%.
When I generated the G-Code and tried to print, it looked a little high. My printer is registering the first layer Z height at 0.3mm.
I went in and checked the G-Code and sure enough it said layer 1 - Z = 0.3
Layer 2 is apparently 0.675
Am I missing something? Please help a newbie!
Re: First Layer Height - What am I missing?
Posted: Tue Feb 16, 2016 6:46 am
Do you have a Z-axis offset?
Also, if you just post your factory file, people could provide much better suggestions instead of just wildly guessing ;)
Posted: Tue Feb 16, 2016 6:41 pm
by Docmani
Sorry, I wasn't sure how to attach a file. I had some screenshots.
Anyhow I played with this last night and determined that I was using a raft and that the initial raft layers were .3mm and .37mm.
So I'm curious if this is normal? I didn't find a place to change the raft layer height. Since it was equal to the nozzle height a found it odd. I thought you needed it to be less than the nozzle height for good adhesion.
