What does print quality setting change?
Posted: Tue Feb 16, 2016 11:16 am
Hi, gang.
So, I picked up Simplify3D a few weeks ago and after a bit of a rough start (due entirely to me and the printer)*, I'm FINALLY getting the results out of my printer that I'd hoped for when I first purchased it. Which raises a question about some behavior that I observed last night. I'm using a Printrbot Simple Metal with a heated bed add-on. I'm constantly trying to do more complicated and bigger prints, as I get more skill and confidence with the technology and the settings.
So I started printing an object on 'High' quality, to see what kind of results I would get. I saw the time increase, as I expected. But when it started printing (in this case, PLA), I saw terrible adhesion to the bed. Instead of a solid line, I saw little blobs strung along like morse code. Then when it did start printing the base level, it started getting blobs and clearly was going to be a dirty print (sorry, forgot to take a pic). I tried then changing the settings to 'Fast' quality and the print appeared to lay down an nice first layer...and i got the best print I've ever gotten off of the printer. I don't think I made any other settings changes. Any idea what those settings changes alter that might explain this? Is this an indication that I'm not close enough to the bed because 'High' settings operate at 0.1mm? Could it be something else? Is it possible that that the extruder is moving TOO slow when on higher settings (currently have first layer speed set to 40%, iirc).
*- Man, nothing validated my purchase of Simplify3D like going back to Cura to try and test a setting. I have become quickly very used to S3D's far more friendly and responsive interface, not too mention the much cleared controls, settings and options. Seriously, Simplify3D is just a great product.
Any suggestions would be appreciated. This is what I printed, btw:
