2 Newbie Questions ...using a CTC Bizer
Posted: Thu Feb 18, 2016 4:26 am
Question 1
I have just started using a CTC Bizer and realised that it uses x3g format files rather than G-code, but there seems to be no option in Simplify3D to output an x3g file to a memory card and yet I can print via USB. Am I missing something?
Question 2
I'm having to try using a memory card becuase while printing with USB, although it works, it will regularly pause and then continue in much the same way as a normal printer might do when spooling to a print queue. I can use the Force Next command to make it start again or I can leave it and after a few seconds it will start printing again. An estimated 45 minute print took 1h 25mins last night to give you an idea of how much it pauses! Is there a setting I can change for the size of the queue or is it going to be something else?
Question 2
