This post is moved from an earlier thread about extrusion failure. see priming extruder issue by HauntedMaestro » Sun Feb 14, 2016 1:27 pm
When I attempt to print, the head moves to the front right corner of the bed, then extrudes a bit of filament, then begins to move the print head as if printing the item. But the printer does not extrude anything. I went back to some test prints that came with my Flashforge Creator Pro. I sliced using the RelicatorG/Skeiforge package that came with the printer, and they print just fine. I went back to some things I had previously sliced/printed using S3D, they failed. I just now downloaded a new thing from Thingiverse, sliced it using the default Process1, watched the preview and it looked ok, but the print failed.
I also use the load filament utility in my printer to verify that ABS does extrude as expected, and let it run for several minutes. Prints still fail because no filament is extruded after the initial spritz at the corner of the plate.
Help!
thanks
russ wolfe
