Konky
More tooltip help/defaults
S3D has an amazing number of options but the tooltips are not so nice.
Usually they give a good idea what this is about and "higher is better" or similar but no real numbers!
I'd like to see something like in Cura, that tooltips contain real life values.
Re: More tooltip help/defaults
In case you haven't seen this yet, there's also detailed documentation for each parameter here as well: viewtopic.php?f=8&t=2367
I found that really useful when I was learning about what each setting does. And you can always reload the default profiles provided by S3D if you want to be reminded what a good default value is.
