Please add an assistant for different layer heights
Posted: Sat Feb 20, 2016 10:35 pm
by Konky
While you work on the automated flexible layer heights already suggested here ;)
I would like to see an assistant that creates a number of processes based on the visually set layer heights (using crossview)
That assistand will create every required process and disable/enable the right features!
For example:
First layer: disable additional top layers
middle layers: disable buttom and top layers, disable slowdown and layer height for first layer
Top layer: disable additional bottom layers, disable slowdown and layer height for first layer
All layers: fills in stop/start at height setting
A few more features are probably missing that need tweaking depending on process area
Right now it sucks a bit because you really have to tweak a bunch of settings by hand every time, it's not as easy as the tutorial said (just set start and stop)
Re: Please add an assistant for different layer heights
Posted: Sun Feb 28, 2016 7:47 am
by frankiehinrgmc
That would be a great feature.
I use a lot of processes, printing my models with large fast'n'rough sections topped with fine and slow settings.
Please add the assistant. :D
