efes
20mm cube abs no pretty
hello
Finishing not pretty ..
or is my problem?
thank you
i have davinci 1.0 extruder e3d lite ;)
http://hpics.li/9b8bd41
http://hpics.li/9df81e4
http://hpics.li/c881cf8
2016 ABS.fff
(10.49 KiB) Downloaded 264 times
Konky
Re: 20mm cube abs no pretty
Use a brim or raft
If you have a heated bed put a cardbox over your printer to increase temperature
Just some ideas, I'd test that and see if it makes a difference.
efes
please help :oops:
WizarDru
Looking at the picture, that looks like a problem of over-extrusion.
Some quick questions:
1. This is ABS?
2. What is the temperature of your bed and extruder?
3. What is your retraction setting?
4. What is your restart distance?
5. What is your extrusion percentage?
For me, setting the last three solved a lot of problems similar to what you had. Also, if your temperature is too low for ABS, you can get material cooling to soon, which could also cause problems with a print.
