Another newbie. Learning from Cura to Simplify3D - help
Posted: Thu Feb 25, 2016 10:15 am
Hi all. I am trying to learn Simplify after being a Cura user. I am new to 3D printing like alot of people.
Look the main thing I am having trouble with is figuring out, what settings in Cura and the same in Simplify due to the different terminology used.
Can someone please point me in the right direction by telling me, what is the relevant Simplify setting, to the below Cura setting:
Layer height - (I think this one is primary layer height???)
Shell thickness
Bottom top thickness (mm)
Fill density %
Perimeters before infill yes/no
Print speed
Printing temp (I got this one figured out)
Bed Temp (I got this one figured out)
Support type (I got the suppport screen figured out OK)
Platform adhesion type
Filament diameter (I got this one figured out)
Flow %
Nozzel size (I got this one figured out)
Retraction speed (I got this one figured out)
Retraction distance (I got this one figured out)
Quality:
Initial layer thickness (mm)
Initial layer line width %
Cut off object bottom (mm)
Speed:
Travel speed (mm/s)
Bottom layer speed (mm/s)
Infill speed (mm/s)
Top/Bottom speed (mm/s)
Outer shell speed (mm/s)
Inner shell speed (mm/s)
Cool:
Minimal layer time (sec)
Now most of those settings I cannot work out which ones they are in Simplify so I am really hoping someone can be bothered to take the time and help me out by putting next to them, which ones are the relevant Simplify settings....
As it is I am blindly guessing and things are not printing either at all, or no where near as good as Cura... and I believe this software is much more advanced then Cura with even more options and settings, and it cost me $150 so I really wanna learn how to make this thing work !!
Shell thickness
Fill density %
Print speed
Flow %
Quality:
Speed:
Travel speed (mm/s)
Infill speed (mm/s)
Cool:
