print temp not updating
Posted: Sat Feb 27, 2016 6:47 pm
by felixdkat
flashforge creator pro
if i make a change in the extruder or bed temp it does not update if i try to print again.
is there a cache of the print that needs to be cleared somewhere?
Re: print temp not updating
Posted: Sun Feb 28, 2016 8:16 am
I would setup the first print, then click "Save Toolpaths to Disk" to save the gcode and x3g files to your hard drive. Then make the change for the second print and do the same thing (just be sure to use a different file name).
Then you can compare the gcode files (since those are plain-text). Are the temperatures in the beginning of the gcode file different? There are plenty of free text file comparison tools that can also make this easy to compare if you don't know where to look.
Resolved: print temp not updating
Posted: Sun Feb 28, 2016 7:31 pm
by felixdkat
CompoundCarl: thanks... yep gcode the same...
Resolved: windows issue.....
for anyone else with the same problem- windows8
started simplify3d in administrator mode (right click and choose "run as administrator") and all is well. now the temp changes show up just fine
