Extrusion Multiplier vs Changing Esteps
Posted: Sun Feb 28, 2016 6:24 pm
when trying to dial settings in say for example you get your esteps setup at 800. you then print some test pieces and determine that you needed to set the extrusion multiplier to .90 to get everything to look proper. is it best to leave that extrusion multiplier at .90 for that specific roll of filament? or can you do some math and just go ahead and change the esteps in the firmware on the machine?
example. esteps @ 800, extrusion multiplier @ .90
would that then mean youre putting the same amount of plastic through the nozzle as you would be if you were printing with the esteps @ 720 (90% of 800) or is that math incorrect? or should it be 800 - (.90% of 800) = 792.8?
