Turn off unused Heater?
Posted: Tue Mar 01, 2016 7:57 pm
Is it possible to turn off the not used extruder when it is running a dual extrusion print?
Simplifying the 3D Experience!
https://forum.simplify3d.com/
Code: Select all
{REPLACE "; layer 100" "; layer 100\nM104 S0 T1"}Yup, I think that would work too. Probably much easier than my suggestionJSField wrote:Also if you add a 'Per-Layers Temperature Setpoint' on the Temperature tab and set the appropriate temperature controller to 0 on layer 100, this should do the same thing?
