Color bleeding problem when Dual Extruding
Posted: Thu Mar 03, 2016 10:43 am
Hello,
Having an issue with Dual Color Prints.
The print consists of a 1mm thick, round white disk that is 40mm across.
On top, I'm attempting to print several words in a different color (black for now).
Basically it's working now but one small issue remains.
On one edge of the round white disk, I get a small areas where the 2nd color has been mingled into the white.
I'm guessing that there is a small bit of filament oozing out of the black extruder and it's getting brushed off onto the white disk then melted into the white.
I'm using an ooze shield but it still occurs.
My thought is that I need to add some custom code that (just before it begins to print the black color) moves the extruder away from the print, does a wipe on the bed, then returns immediately to the previous location and begins printing.
I don't see how else I can prevent ALL oozing from the black nozzle enough to fully prevent this.
Any suggestions would be welcomed.
