Start point in concave location
Posted: Sun Mar 06, 2016 10:02 am
by hakimio
While in general Simplify3D gives much better results compared to Slic3r, there is one problem with S3D - it makes the seam much more visible compared to Slic3r. It would be great if there was a setting to tell S3D to automatically choose start point in a concave location when possible (otherwise put all the start points in one single line closest to the chosen point).
Re: Start point in concave location
Posted: Mon Mar 14, 2016 8:38 pm
by kejocu
Yes! This is the main thing that Slic3r does better than S3D.
Posted: Tue Mar 15, 2016 2:43 pm
by NitroXpress
If your printer and S3D is perfect adjusted, S3D can create nearly unvisible seams.
No matter where the seam is located, except in corners,
Thanks to coast/wipe function !
Unfortunately Slic3r don't have an adjustable coasting option.
However the concave option would be nice...
Frank
Posted: Sun Mar 20, 2016 3:10 am
by KC_703
While you can't specify a start point for a concave face, the start point for a layer can be specified to a XY location. With this feature, the start point of the concave face should be constant... just not specific to the face.
So to print a predictable layer seam, specify middle-back location of the printer as the start point. Then rotate and place the model so the back corner is closest to the middle-back of the printer. This should produce a consistent layer seam along the back corner.
Posted: Sun Mar 20, 2016 3:40 am
by NitroXpress
Yes, this is the only workaround at the moment.
But much effort and sometimes impossible when printing multiple parts.
The better way would be, to perfect the retract/unretract settings with different speeds proposed here:
viewtopic.php?f=23&t=689
Frank
