support material extrusion width
Posted: Wed Mar 09, 2016 5:55 pm
by maker2
If one is extruding wide traces in general for ones print then the support material can get a bit "heavy".
It would be nice to have an extrusion width specify for support - as there is for infill - so as to be able to slim it down.
Re: support material extrusion width
Posted: Wed Mar 09, 2016 8:49 pm
by KC_703
Try the dense support layer function.
Specify a low support density (15-25%), then use 3 layers for dense infill percent of 70%. The lower support density should help keep the supports from becoming "heavy".
Posted: Fri Mar 11, 2016 2:16 am
by thechupathingy
I too would like this, It's a feature I miss having used Skeinforge for so long. I miss the ability to tune everything
