I'm getting extra material in the corners with the floor and the roof. Also at the top around the edge there is a tiny bit of a ledge.
Would the coasting settings fix this?
I have one corner where it moves from the inner wall to the outer wall.
It's moving at full speed between the two. Causing the corner to be extremely ruff. Is there any way to control this speed or ram up and ram down of the hot end?
