Dual Extrusion Missing command
Posted: Fri Mar 11, 2016 8:08 am
The dual extrusion process can't print something well because it's missing a command in the GCode generated by S3D.
To avoid oozing during the print of the first tool, it's recommended to implement in the startupscript the first retraction for changing tool. For example, this is my startup script :
T1 ;switch to the 2nd Extruder
G92 E0 ;zero the extruded length
G1 F200 E13 ;extrude 13mm of feed stock
G92 E0 ;zero the extruded length again
G1 E-15 F3000 ;retraction before toochange
T0
then the print begining, and the first tool which print something is the T0. There is no issue with this tool because S3D generate a retraction and an extrusion to compensate this retraction just before the print.
But the issue appear when it's time for the T1 tool to print something for the first time.
This is a part of the generated GCode from S3D regarding the change between the first layer of the T0 tool and the first layer of the T1 tool :
G92 E0
G1 E-15.0000 F3000
; layer 2, Z = 0.2
T1
; prime pillar
G1 X81.968 Y160.384 F12000
G92 E0
G1 X90.568 Y160.384 E0.1078 F1442
As you can see, the T0 perform a retraction of 15mm to avoid oozing (like a I add in my startup script for the T1), but the T1 is positing, reset the extruder and start to print without perform a G91 E0 F3000 command. So on my case, the nozzle is empty because I made a retraction, and if I hadn't retract, the noozle could be empty too because it was oozing during the first layer.
Bellow this is the transiltion layer script perform by S3D for all others layers :
G92 E0
G1 E-15.0000 F3000
; layer 74, Z = 3.8
;change tool script
T1
; tool H0.100 W0.400
; inner perimeter
G1 X97.293 Y148.083 F12000
G1 E0.0000 F3000
G92 E0
Here you can see that S3D generated the G1 E0 command to compensate the previous retraction.
T0
G92 E0
G1 E-15.0000 F3000
; layer 2, Z = 0.2
T1
; prime pillar
G92 E0
G92 E0
G1 E-15.0000 F3000
; layer 74, Z = 3.8
;change tool script
T1
; inner perimeter
G1 E0.0000 F3000
G92 E0
