Which setting to cure this zipper effect
Posted: Sat Mar 12, 2016 6:34 pm
In the attached images you can see a cylinder object that has little zits if you will running down one side (the rest of the object is perfect). I assume this is either where it changes layers or switches to infill.
Now for structural reasons this object has only 1 perimeter but 100% infill in case that makes any difference. I am so close to perfection I can taste it.
Printer is a TAZ 4 converted to a TAZ 5, .40mm nozzle, ABS 245c bed 100c on Buildtak Top speed 80mm/s perimeter 70mm/s
