Heated bed plate settings acting squirrly on Replicator 2
Posted: Tue Mar 22, 2016 5:44 pm
by SHoutzager
I added a heated bed plate to my Makerbot Replicator 2 and then altered S3D with these settings. http://3dprinting-blog.com/498-how-to-u ... implify3d/
The first print worked well and the plate heated up first. Now I am unable to get the plate to heat up. Nearly every time that I go to my Firmware Configuration settings S3D will have snapped back Replicator 2 default instead of Replicator with HBP. I will reset it and hit Save.
I added the GCode and I know that it has worked once.
The plate works because I can heat it up thru the control panel on the replicator.
Best!
S.Houtzager
Re: Heated bed plate settings acting squirrly on Replicator
Posted: Wed Mar 23, 2016 6:29 am
You probably have your process settings set to override the firmware configuration. So you need to make the GPX change directly in your process settings (on the G-Code tab).
You can learn more about this here: https://www.youtube.com/watch?v=NYPUAqT4UyI
Posted: Wed Mar 23, 2016 9:36 am
by SHoutzager
That did the trick, so far!
