Settings changes for quality change
Posted: Wed Mar 23, 2016 5:02 am
by pinthenet
I have been printing for a few months @0.2mm (Vertex K8400) and I've tuned the process settings to get reasonable to good results. I'd now like to do some printing @0.1mm and I am assuming I can't just change the layer height alone, and that some settings will need to be adjusted. Is this summarised anywhere?
Thanks for any pointers
John
Re: Settings changes for quality change
Posted: Sat Apr 02, 2016 10:35 pm
by AreDigg
As long as your printer are able to print it, layer height should be the only option. However you may or should also need to double the initial layer height setting.
Posted: Wed Apr 27, 2016 11:13 am
by MartinNicolay
Hi John,
i just startet to use Simplify3D with my K8400.
It is a great pice of Software but the results are not as good as it was with the cura engine.
so it would be nice if you can share the settings u made with me/us?
Thanks in advance
Martin
