Right Extruder Only
Posted: Thu Mar 24, 2016 6:36 am
by JerrPlust
When I enter the option "Right Extruder Only" (Auto-Configure Extruders) in my process and start to print, also the left extruder is heating up.
Do I forgot something in the settings?
Thanks,
Jerry
Re: Right Extruder Only
Posted: Fri Mar 25, 2016 7:47 am
What printer are you using? And just to be sure, why are you saying the left extruder is heating up?
Posted: Sat Mar 26, 2016 11:12 am
by JerrPlust
I use a geeetech Delta g2s printer (Marlin).
I mean that both extruders heating up.
So when I only needed right, left is also heating up.
Posted: Sun Mar 27, 2016 3:23 pm
Again, WHY do you think both extruders are heating up? How are you measuring the temperature? I've seen many people get the extruders mixed up in the machine control panel or get confused when one extruder goes to 40 degrees while the other is at 230C (ambient environment easily causes this rise).
It would probably also help if you posted your factory file so other people could see exactly what settings you entered (File > Save Factory File)
