Good morning everyone! I am searching a way to adjust the acceleration and jerk for the first ''X'' number of layers. Obviously to help adhesion of the first layer. I am using Repetier Firmware
// ************ Something like ************
If ( Z < 0.6)
Set jerk;
Set accel;
Else
Load values from EEPROM;
I am using Simplify3D and it has some speed reducing function (not accel) for the first layer but are very limited. My best solution so far is the manually add M201 M202 M207 in the Gcode.
I am also trying to learn how to make MXXX function within the firmware, this will probably work but I am not there yet. In Simplify3D there is an ‘’layer change script’’ option that can push G and M code at every layer change. One of my idea is to create a MXXX function that is call at every layer and if the height is below Y, it change the parameters.
Any solution?
thank you
