Redrichie
Cube pro trio help please
I've used the fff files from another thread and have had awesome prints from extruder 1&2 but I can't get the third to print. All the scripts make the print head move to the waste bin and then heat but then it never goes to ready and primes the hot end. I don't know if it's chamber temp not reaching a set ppint or a pice of background d code is missing. I've went line by line from the extruder 1&2 presets and everything seems to match experience where it differentiates the extruder number, material etc. Any help welcome.
apostolise
Re: Cube pro trio help please
Hello, I am sorry I don't have an answer but I have a related question.
I am new user I have a Cube Pro Duo and I haven't figured out how to make Simplify3D work with extruder no2. Where do i select which extruder to use?
Thank you in advance.
I think the profiles from some of the older forum threads only work with the previous version. If you're running version 3.1, they already have profiles included for the CubePro. So just go to Help > Configuration Assistant, and select your CubePro version (i.e. single, duo, trio)
Redrichie
Fantastic. Yes they do. Nozzle 3 has been pleasantly printing away all day. I did have to change my first layer height to 75% but other than that I've been printing stock prifiles. Thanks S3d and whomever made that possible. This is such good news. Has anyone tried out using any nozzle to print the the rinse away support yet?
joestefano
Are you using bulk filament? I have a CubeX Trio how similar is the Pro? I'm using Kisslicer now with bulk filament.
Redrichie
Sorry for the delay. No I'm using standard 3d systems filament. Just getting that to work in the three jets reliably is fantastic. Don't know if it's possible to bypass in the pro. If it is I would love to know how as well.
