Definitely possible to use the Autocnfigure subprofiles to manage nozzle size... But I also use a separate profiles for different nozzle sizes.
The following parameters are stored with the Autoconfigure Material (extruder settings, temp):
<autoConfigureMaterial name="ABS-BLACK-LH2">
<extruder name="Primary Extruder">
<toolheadNumber>0</toolheadNumber>
<diameter>0.5</diameter>
<autoWidth>1</autoWidth>
<width>0.6</width>
<extrusionMultiplier>0.92</extrusionMultiplier>
<useRetract>1</useRetract>
<retractionDistance>1.7</retractionDistance>
<extraRestartDistance>0</extraRestartDistance>
<retractionZLift>0</retractionZLift>
<retractionSpeed>1800</retractionSpeed>
<useCoasting>1</useCoasting>
<coastingDistance>0.2</coastingDistance>
<useWipe>0</useWipe>
<wipeDistance>5</wipeDistance>
</extruder>
<temperatureController name="Primary Extruder">
<temperatureNumber>0</temperatureNumber>
<isHeatedBed>0</isHeatedBed>
<relayBetweenLayers>0</relayBetweenLayers>
<relayBetweenLoops>0</relayBetweenLoops>
<stabilizeAtStartup>1</stabilizeAtStartup>
<setpoint layer="1" temperature="245"/>
<setpoint layer="10" temperature="243"/>
</temperatureController>
<temperatureController name="Heated Bed">
<temperatureNumber>1</temperatureNumber>
<isHeatedBed>1</isHeatedBed>
<stabilizeAtStartup>0</stabilizeAtStartup>
<setpoint layer="1" temperature="110"/>
<setpoint layer="20" temperature="100"/>
<setpoint layer="150" temperature="90"/>
<globalExtrusionMultiplier>0.91</globalExtrusionMultiplier>
<fanSpeed>
<setpoint layer="1" speed="0"/>
<setpoint layer="2" speed="50"/>
<setpoint layer="4" speed="0"/>
<setpoint layer="10" speed="30"/>
<setpoint layer="35" speed="40"/>
</fanSpeed>
</autoConfigureMaterial>
FWIW, the Autoconfigure Quality settings contain layer height and speed parameters:
<autoConfigureQuality name="LH2-SPEED4800">
<globalExtrusionMultiplier>0.92</globalExtrusionMultiplier>
<layerHeight>0.2</layerHeight>
<topSolidLayers>10</topSolidLayers>
<bottomSolidLayers>10</bottomSolidLayers>
<skirtLayers>1</skirtLayers>
<skirtOutlines>5</skirtOutlines>
<infillPercentage>20</infillPercentage>
<supportInfillPercentage>25</supportInfillPercentage>
<defaultSpeed>4800</defaultSpeed>
<outlineUnderspeed>0.4</outlineUnderspeed>
<solidInfillUnderspeed>0.8</solidInfillUnderspeed>
<supportUnderspeed>1.1</supportUnderspeed>
<rapidXYspeed>5400</rapidXYspeed>
</autoConfigureQuality>
