First Layer Refinement - Go Away Distinct Filament Lines
Posted: Sat Mar 26, 2016 11:25 pm
Assembled an Original Prusa i3 a couple weeks ago as my initial introduction to 3d Printing and have been having a blast since then. Started with Cura, and after reading comments about Simpifly3D, decided to invest in it. Had it about a week and in general, print quality is on par, or better than Cura, with one exception - first layer printing.
I've been focusing in PLA for the time being, using some Inland PLA, since MicroCenter is close by.
I've had great success with Cura for printing a set of vases, basically right out of the box - load and print - beautiful.
The wide variety of settings in Simplify3D obviously required a little more rigor, and I downloaded some Original Prusa i3 profiles to start with.
Generally, when printing from gcode generated by Simplify3D, the first layer shows a very distinct pattern for the filament with very narrow separation between the strands, shown on the V2 / V3 test blocks I'm using pictured below.
I've been adjusting:
I have been able to make the filament strands on the first layer "fatter" and stable with:
Being very new to 3D printing, I was just wondering if the bottom layer could be tuned to look more like to the top layer, which always turns out very nicely.
I've attached FFF exports for:
It would be really nice if Simplify3D did a better job of letting you start with an existing name when saving new profiles, or generating print files, like it does when exporting an FFF. Even better yet, be able to show a report or detail on the difference between 2 profiles.
Any thoughts or guidance would be greatly appreciated. I've gone through the print quality guide, but haven't been able to get this put to bed.
Ray
- FirstLayerHeightPercentage
- OutlineOverlapPercentage
- firstlayerwidthpercentage
- fanspeed - layer 1 = 0, layer 5 = 100
- extruder multiplier between 0.95 and 1.05, with 1.0 being the best (v2) above
But, the individual strands are still visible.<firstLayerWidthPercentage>200</firstLayerWidthPercentage>
<fanSpeed>
<setpoint layer="1" speed="0"/>
<setpoint layer="4" speed="100"/>
</fanSpeed>
- V2
- V3 - first layer 'stranding'
- V5 - fatter layer
Ray
