locdown
Da Vinci 1.0A Buffer 0
Good morning everyone. I have an issue. I own a Da Vinci 1.0A and it was flash with Rep so I would be able to use S3D. The last couple of weeks when I go and print the Buffer is on 0 (zero) and I take a look at the Communication tab in S3D and all I see is Received:wait. It goes on for a long long time before it begins to print. I use USB and I did change my Communication serial cache size to 127. Still nothing. When it does print after a few minutes to goes right back to 0 Buff and nothing happens. What take 30 min to print turns out to be hours.
Re: Da Vinci 1.0A Buffer 0
You can use S3D with the stock firmware, so you don't have to flash to repetier just to use S3D
Also, there's been many similar threads recently, so it might be good to search: search.php?keywords=vinci+repetier
locdown
Thanks for the reply. When I installed S3D with the Da Vinci out of the box I was able to connect but not able to control anything at all. Jog Control...nothing. Thats the reason why i flashed it. Thanks for the link.
