S3d not printing built in supports
Posted: Tue Mar 29, 2016 9:33 pm
by vincerules
I was trying to print this croc:
http://www.thingiverse.com/thing:941177/#files
Specifically crocz.stl with the built in supports.
When I load it into s3d it looks fine:
but when I go to save toolpath to disk it got rid of the supports:
I am printing on an ultimaker 2+ using ths default ultimaker 2 settings that have worked for other prints.
Any ideas what I should check/change?
Re: S3d not printing built in supports
Posted: Wed Mar 30, 2016 5:39 am
Well first of all, those supports are only about 0.3mm thick, and you set the software to use a fixed 0.4mm extrusion width, so that's why they aren't printing (more info about this here:
https://www.simplify3d.com/support/prin ... ng-printed)
But more importantly, I would STRONGLY recommend using the supports that S3D generates natively instead of trying to do it yourself from the CAD package. S3D does a lot of really smart things with their supports, and you lose all that functionality if you manually model the supports yourself like in the model you posted.
So I would just select the version WITHOUT supports added
Posted: Wed Mar 30, 2016 11:55 am
by vincerules
Thank you for the response.
I will stick to the s3d generated supports that have worked great for many other prints.
Posted: Fri Apr 01, 2016 9:57 am
by AIBLTD
Hey CompoundCarl,
I don't quite understand the you mean by 0.3mm thick support. What/where do you refer that to? As for fixed 0.4 extrusion width, this I get it is under Extruder/Overview, but how should I set those parameters, say deducing by what?
Lastly, there is not any paragraphs describing solutions to not able to print supports from the URL you mentioned. Did I missed something?
Thanks!
-Gideon
Posted: Fri Apr 01, 2016 10:09 am
by AIBLTD
Oh wait, I kinda get it. It is like I have to go to the Support section to play around those parameters.
Posted: Fri Apr 01, 2016 10:25 am
by zemlin
It has to do with thin-wall slicing. If the modeled supports are thinner than the extrusion then S3D will not print them.
Posted: Fri Apr 01, 2016 10:45 am
If you're still confused about what is referred to as thin walls, take a read through this thread and the threads it references:
viewtopic.php?f=23&t=3471
Posted: Tue Apr 05, 2016 10:38 am
by AIBLTD
Alright guys, thanks for the links and tips! Lemme spend sometime reading them.
