Top layer issue
Posted: Wed Mar 30, 2016 7:25 pm
This issue is driving me nuts. I use to get cleaner top layers on my TAZ 5.
Now I thought it was an infill overlap issue (normally set to about 10%) but I have taken it down to 0 and up to 30 without the issue changing much at all.
Now, I don't believe I am over extruding as the infill lines barely touch each other, if I reduce the extrusion a small amount then there is a gap between the infill lines.
I have also raised and lowered the perimeter overlap amount again with very little change.
So when the infill changes direction at the edge there is an excess of material, otherwise the print is fine.
Any ideas?
Any ideas?
