Top Layers Not Solid
Posted: Thu Mar 31, 2016 1:24 pm
by ayouden
Hello,
I know in other slicers you can edit the top layer infill extrusion width to try and eliminate the issues in the attached images.
I have had a look in the settings and haven't been able to find anything.
Does anyone have any tips?
(Using a Makerbot Mini)
Thanks in advanced!
Regards,
Alex
- Gap in Top Layer
Re: Top Layers Not Solid
Posted: Fri Apr 01, 2016 6:17 am
Your top layers look very solid to me, except for the one outer ring. I have a feeling there's something else going on there and would be very doubtful that the solution is to extrude more since all other parts of the print look fine.
Posted: Fri Apr 01, 2016 12:13 pm
by ayouden
Hello,
It would appear my second attachment failed to attach!
As you can see, there is the gap in the G-Code, so this is what makes me think there is something I can do to make it fill the gap in!
Regards,
Alex
Posted: Sat Apr 02, 2016 11:41 am
Yup, that's probably an easy fix. You just need to adjust your thin wall settings.
Post your factory file and it will make it easier for people to give suggestions (File > Save Factory File)
Posted: Mon Apr 04, 2016 5:47 am
by ayouden
I have attached the factory file for you.
Regards
Posted: Mon Apr 04, 2016 7:12 am
by jimc
Yes there is no room to put another extrusion there. Lower your perimeters to 2 so there will be more room for infill.
Posted: Mon Apr 04, 2016 7:33 am
Increasing the "outline overlap" setting on the Infill tab to 30% will also help, since it allows more space for the gap fill
