OK I have a small print volume. but I can enlarge and print in pieces to get what I want larger.
is there a way to SELECTIVELY enlarge?
for example I am printing the space plane spiral mode model. I enlarged it told it to only print the first 125mm. Good got that.
then I dropped the model into the build plate by 125mm so I can print the second part.
when I do a non uniform scaling I can stretch the model to make it longer or shorter. but this is critical. I need to "NOT" reshape or scale the portion of the model touching the build plate since that will prevent the parts from "mating" together when I try to put them together.
can I pick 2 z axis heights and stretch or compress the model "only" between those selected points? this way I can bring the wings further back with a compress and stretch the nose longer with a stretch to make it more "flight stable" (pushing to the CP back and nose forward to push the CG forward which a rocket will need to be stable)
any ideas?
