Reduce vibrations from narrow infill
Posted: Sat Apr 02, 2016 2:23 pm
by AreDigg
When I print using higher speeds, and when the infill are being printed where width is maybe around 1-3 mm, the movement of the printhead back and forth creates an intense vibration. I have tried dampening, but I think it would help to have an option to slow down the speed while printing. The reason being that for certain material that are not easily sticking and objects tall and small, will become loose from the vibration.
Re: Reduce vibrations from narrow infill
Posted: Thu Apr 07, 2016 11:57 am
by zemlin
Reducing the accelerations on your X and Y will reduce the vibration and head speed when printing itty-bitty things. You can do this in the startup script.
http://reprap.org/wiki/G-code#M204:_Set ... celeration
Posted: Fri Apr 08, 2016 10:55 pm
by AreDigg
Thanks, it helps. But I wish that the slicer could lower the acceleration only when making the narrow infills, not for the entire print.
