Can See Model Detail in Print
Posted: Sat Apr 02, 2016 11:29 pm
I am having trouble with models I design. I can see the underlying structure I built the STL file with, the circles, lines, rectangles, etc. I am using Fusion 360 for design.
I'm not sure where to start, but thought I'd toss it out here to see if anyone has ideas...
Below is an image from Simplify 3D with a part rendered. The part was created with two side-by-side circles and a connecting line across the top and bottom. You can see the path the 3d printer takes and the final part shows this underlying structure rather than a continuous surface.
Any tips?
Thanks in advance!
https://www.dropbox.com/s/2ujggboh17c0w ... g.png?dl=0
Any tips?
Thanks in advance!
