inclined supports
Posted: Mon Apr 04, 2016 1:38 am
by jf pion
Hello, i'm new to S3D . i got it mainly for the advanced support management. but ther is still some problems . when you try to slice the voronoi type stl (like the fox in attachment) if you want a support under the chin the support go thru the part to the be making it inextricable. if you make it fromethe upperside of the part it is too fragile and the voronoi make the print uncertain so the support often fall down or leave some traces difficult to remove because of the very weak part.
is there a way to make the supports manualy inclinable to avoid the printed part (as click on the bed side of the support to drag it outside the part ?
thank you
