ARTISAN
layers adhesion
so ive upgraded my slicer to S3D..
the prints are a lot cleaner...and the overall look it beter...
but ive goten that
and if you cant see in my 4K picture
the first layers got poor adhesion...broke apart very easy
like i said...the prints do look cleaner somehow
but the overall strength/sturdiness is weaker
any Suggestions??
cheers.!
Re: layers adhesion
There's lots of ways to change the strength of the part - add more perimeters, add more top/bottom solid layers, increase the infill percentage, increase the infill extrusion width percentage, etc
nerys
Re: layers adhesion
in my personal EXTREMELY limited experience I lost layer adhesion when the temperature was dropped too low
before simplify I kept lowering the temperature in makerbot desktop because of the stringy wisps I was getting.
lower temperature helped but I lost layer adhesion. I could pull prints right apart.
SO as an easy to test suggestion raise the temperature 5' and see what happens if it helps but not enough another 5'
I find I need to print at 215-217 for pla on my replicator mini and simplify has almost no stringies compared to makerbot desktop.
MichaelHerron
Re: layers adhesion
ARTISAN wrote:so ive upgraded my slicer to S3D..
but ive goten that
any Suggestions??
cheers.!
If your prints look great, but your layer adhesion is poor, your first move should be to increase temperature. try 5 degrees and see what happens.. if still poor, give it another 5.
