Changing default extruder temperature
Posted: Tue Apr 05, 2016 6:32 pm
by root
I want to change the default extruder temperature? In my firmware it is set at 200C. But I want to change it so that it holds for the whole print.
In the Temperature tab of FFF (Process) Settings...I set the Layer 1 setpoint to my new temp (see attached). Is that enough for all layers of the whole print?
Thanks for any help!
Re: Changing default extruder temperature
Posted: Wed Apr 06, 2016 7:35 am
Yes, since you only have one setpoint, if you change the temperature for layer 1 it will set the temp at layer 1 and then remain constant for the entire print.
Posted: Wed Apr 06, 2016 7:27 pm
by root
CompoundCarl wrote:Yes, since you only have one setpoint, if you change the temperature for layer 1 it will set the temp at layer 1 and then remain constant for the entire print.
Thanks !!
