pyroboynroses
Auto configure settings disappeared
Hello,
Quite new to Simplify3D, I like to make different profiles, with different qualities and materials.
But suddenly, the autoconfiguration vanished from the screen (see attached screenshot).
It's doing this on one or two profiles on my list, the other are OK.
The NOK profile screenshot : http://hpics.li/0eec303
The OK profile screenshot : http://hpics.li/a54e4de
Thank you !
Re: Auto configure settings disappeared
Well what changes did you make between the 2 profiles? You can always go to File > Export FFF Profile to export both profiles to your hard drive and then compare them in a text editor.
camera
It happened with me too. The "Auto-Configure for Material" and "Auto-Configure for print Quality" had suddenly disappeared from my usual profile. But in the Default profile it was appearing normally. I didn't know what was happening. And I hadn't a exported profile yet...
To solution this problem, I had to recover the file "savedState.factory" in "library/application Support/Simplify3d/S3D-Software/" from my previous backup on my Time Machine.
After that I started the S3D again, I renamed the profile with a new name and I exported it to a findable folder on my Mac (with another name too) . Then I deleted the older profile name.
Now my S3D is working normally. By the way, I have done another backup of the profile file (.FFF) and savedState.factory.
I'm using a S3D 3.1.0 on a iMac 10.9.5.
