Every process selected when preparing to print?
Posted: Sat Apr 09, 2016 4:38 pm
by A3D
What is up with every single process being selected when preparing to print?
Does anyone ever use every single process they've ever created to slice a print? This seems like a glitch, not a feature.
I have different processes for different types of parts (Low quality sample, structural, fast, dual extruder, etc), and when I click "prepare to print" it has every single process highlighted in the "Select Processes for Printing" window. I'm only using 1 process at a time for my single extruders and 2 for my dual extruders, why is every single process selected every single time? Especially since there's the "Processes (double-click to edit) pane on the main page, where you can select the process beforehand. Why doesn't the "select Processes for Printing" window start with that process I already selected highlighted, and let me choose if I want to select other profiles. Right now you have to "select None" then go and select a profile you already had selected when you hit "prepare to print".
Re: Every process selected when preparing to print?
Posted: Mon Apr 11, 2016 9:58 am
by dsegel
You should be putting your different settings in Profiles, not Processes. It's just how the program is designed. For example, see my list of Profiles, all contained within a single Process.
Multiple Processes should only be used when you want to change the print settings mid-print for a specific model.
