What settings can I change to fix this issue (pic inside)
Posted: Wed Apr 13, 2016 9:06 pm
by Choumarin
Hi all,
What settings can I change to fill that gap between very close perimeters?
Thanks a lot.
Re: What settings can I change to fix this issue (pic inside
Posted: Thu Apr 14, 2016 6:55 am
Personally, I would probably go to the Extruders tab, and set the extrusion width to manual. Then just increase it a tiny bit until you can perfectly fill those spars. You can keep adjusting and checking the preview till you have it just right.
Posted: Fri Apr 15, 2016 1:16 pm
by Choumarin
Seems to be fixed by increasing the 'Outline overlap' to 30%. I didn't want to increase the extrusion width because it affects parts fitting together.
