Printing M4 bolt?
Posted: Thu Apr 14, 2016 9:50 am
I need to print essentially an m4 bolt. The issue i have is that the m4 bolt at ~4mm in diameter is really thin and it ends up being printed a bit wiggly and the threads are not even.
I believe this is a problem with the print speed as well as heat. I am pretty new to simplify3d software (I have an xyz Davinci 1.0).
How can i make an M4 bolt come out good?
I can print m6 bolts just fine, but smaller than 5mm and problems start happening with cylinders.
