Preview screen build table wrong size
Posted: Thu Apr 14, 2016 6:52 pm
Hi all,
I just ran into an issue where I was scaling a model up so it filled most of the build table in the preview mode but when I started to print the model the print head went way off the table. Upon looking closer at the preview mode table, it became apparent that it did not render the table to the specs I input for my build platform settings. My build table is 250 diameter but the clamps take up some of the outer edge so to be safe I input my build table as 230 diameter in the settings to avoid the clamps. After seeing the print head go off the table I counted the size of the preview mode's table's grid spacing and it is showing on screen as over 300mm diameter. I thought it rendered the virtual preview table based on the actual size you input in the machine settings in the Options in the tools menu. This also explains why the print head goes way off the table when trying to level the bed using the wizard. Anyone know how to fix the virtual tables display size to properly reflect the actual build table??? or is this even possible. Seems weird to provide a table that is not representative of the actual hardware...
